Date/Time: Sat, 01 Mar 2025 20:09:09 +0000
Backtesting order Lines
View Count: 688
[2021-10-17 23:35:30]
User925260 - Posts: 30
I am doing some backtests on bitcoin binance futures and when I backtest it it shows me the order arrows for the entries and exits but it is not showing me the trade lines from each order. Please let me know how to enable and display the trade lines on the chart.
Roger
imageOrderLines.jpg / V - Attached On 2021-10-17 23:34:51 UTC - Size: 276.86 KB - 168 views
[2021-10-18 05:15:08]
We do see the entry/exit connecting lines in that chart. So that is all you are going to see. You are not going to see the original Order lines or Position lines.
Date Time Of Last Edit: 2021-10-18 05:15:36
[2021-10-21 14:44:04]
Yes but on one system it show but on the other system i am doing backesting and it is not showing, how do i enable the lines between trades?
[2021-10-21 14:56:11]
John - SC Support - Posts: 38292
Refer to this setting:
Global Trade Settings Windows: Display Entry/Exit Connecting Lines (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
