Date/Time: Sat, 01 Mar 2025 19:38:57 +0000
Нужно продлить аккаунт
View Count: 546
[2021-10-17 15:15:01] |
User185037 - Posts: 21 |
После первого запроса на продление аккаунта у меня появилась в кабинете возможность оплатить Real-Time Data Connections 25.00 USD [Prorated to 13.00 USD for current month (14 days)] (Non Refundable) Если я пополню счет на 13 usd, я смогу завтра работать с графиком XAUUSD так же как на пробном варианте? Нужно ли доплачивать еще за что ни будь? Пожалуйста ответьте как можно подробнее. Что мне сделать, чтобы завтра работать с графиком XAUUSD изпользуя footprint и market profile? |
[2021-10-17 16:54:11] |
John - SC Support - Posts: 38292 |
From Google Translate: After the first request to renew my account, in my account, I got the opportunity to pay for Real-Time Data Connections 25.00 USD [Prorated to 13.00 USD for current month (14 days)] (Non Refundable)
If I replenish my account with 13 usd, will I be able to work with the XAUUSD chart tomorrow in the same way as on the trial version? Do I need to pay extra for anything else? Please answer in as much detail as possible. What can I do to work with the XAUUSD chart tomorrow using the footprint and market profile? We are confused by the reference to the "Real-Time Data Connections 25.00 USD [Prorated to 13.00 USD for current month (14 days)]" as that is the Sierra Chart Exchange Data Feed, which you are not using. Nor do you need it for the XAUUSD symbol. Therefore, you can put that aside as something you do not need. The FOREX real-time data in Sierra Chart are provided at no extra cost. So as long as you have an active package, you can get the data for any forex pair that we support. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-17 17:32:37] |
Сегодня кончается мой демо режим. Подскажите какой пакет нужно купить, что бы пользоваться графиком XAUUSD. Я прочитал много информации по подключению пакетов, но мало что понял. Все так запутанно. Обьясните как можно проще - что купить, что бы я смог завтра пользоваться графиком XAUUSD вместе с футпринт и рыночным профилем?
[2021-10-17 17:51:58] |
Я понял, что цена пакета спишется полностью, независимо от середины текущего месяца. В связи с этим, могли бы вы мне продлить пробный период до конца месяца, после чего в новом месяце я приобрету пакет.
[2021-10-17 18:40:37] |
From Google Translate: My demo mode ends today. Tell me which package you need to buy in order to use the XAUUSD chart. I read a lot of information on connecting packages, but I didn't understand much. Everything is so confusing. Explain as simply as possible - what to buy so that I could use the XAUUSD chart tomorrow together with the footprint and market profile?
I realized that the price of the package will be written off in full, regardless of the middle of the current month. In this regard, could you extend the trial period for me until the end of the month, after which in the new month I will purchase a package.
The package you need is Package 5. This is because you specifically are asking for the Footprint and Market Profile, which are only part of the Advanced Package. You do not need the Denali Exchange Data Feed, since you are wanting to track FOREX, therefore you do not need packages 10, 11, or 12. You do not need to worry about the middle of the month. When you purchase a package, it is for 31 days from the time that you make the purchase. So if you purchase tomorrow (Monday, October 18, 2021) your next renewal will be on November 18, 2021. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
