Date/Time: Sat, 01 Mar 2025 19:05:38 +0000
TPO Value Area Lines Study - How to extend every TPO line
View Count: 722
[2021-10-15 18:11:53] |
User464833 - Posts: 13 |
I want the study to plot me every TPO POC line, with a horizontal line from left to right, so I can see every TPO POC at all times. Example: if today is friday, I want to see TPO POC from monday, tuesday, wednesday, thursday, etc at the same time. I have tried several draw style types but none of them seem to do this. For example: - Line at Last Bar Left to Right: only plots the TPO POC from the day in which I am currently located in the chart. If I am watching friday activity, it plots friday's POC, if I am on tuesday, it only plots tuesday's POC. - Line From End of Chart Left to Right: only plots the TPO POC from the current day, no matter where I am on the chart. - Etc. Is there a way to do this? Thanks! |
[2021-10-17 15:10:04] |
John - SC Support - Posts: 38292 |
There is not an easy way to do this. The only thing we can think to do would be to have a copy of the chart without the TPO on it, and then add the TPO Value Area Lines to that chart (this will give you the POC) and then use the Study/Price Overlay to get those values into the TPO chart. Then you could use the Spreadsheet Study to actually get the lines displayed across the chart (i.e. you would want to have each line in its own column). It should be doable, with at least a fair amount of manual interaction. It might be able to be done with some good spreadsheet formulas to get everything lined up the way you would want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
