Date/Time: Sat, 01 Mar 2025 16:51:34 +0000
Multiple windows in one chart
View Count: 1779
[2021-10-15 14:51:39]
Galmik - Posts: 37
Hi There! Hope u r well guys!!
Wanted to ask u how can I see some charts i have downloaded in multiple windows ? I want to open one file and have many windows with those charts and not having to open them one by one all the time.
Thank You,
Mike
[2021-10-15 16:24:12]
John - SC Support - Posts: 38292
We are not sure we fully understand your question.
A Chartbook contains multiple charts. You can detach charts from the main Sierra Chart window, so you can move it anywhere on your monitors. You can then do this for any/all of the charts in the Chartbook. When you do this, if you save the chartbook with the layout, it should open up in that same layout the next time you open it.
Refer to the following information for Detaching/Attaching a chart:
Detaching and Attaching Chart Windows
You can also tile the charts within the main Sierra Chart window. Refer to the following and the sections after it:
Window, CB and CW Menus: Tile Horizontally (Window)
