Date/Time: Sat, 01 Mar 2025 17:12:24 +0000
TPO Chart Values Label
View Count: 413
[2021-10-15 13:05:27] |
net-worth - Posts: 5 |
How do I change the chart values label when I display chart values below my TPO profiles? Specifically, how do I remove the (165 ticks) from the screenshot I posted. The example on the right side of screenshot is from a different user, I would like mine to look like that.
[2021-10-15 14:07:41] |
The value in ticks is not removable. It is possible they are running an older version that does not show that. What we could do though is create a separate label. One for range as an actual value and one for range in ticks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-15 14:09:36] |
That would probably be a good solution. Thanks
