Date/Time: Fri, 02 Oct 2026 16:42:53 +0000
Clock-RealTime study high CPU usage
View Count: 856
| [2021-10-15 04:35:27] |
| User629461 - Posts: 213 |
I'm getting high CPU usage for the app (35-40%) when I have this study on. When its not on, CPU usage is 1-2%. I only have it loaded on one chart. There's no mention of high CPU usage in the resource docs like there is for some other studies (eg Countdown Timer) Is there any soluton? Date Time Of Last Edit: 2021-10-15 04:38:40
| [2021-10-15 10:29:13] |
You need to increase the Chart Update Interval of the chart: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) The issue has to do with the complexity of the graphics display of that chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-15 10:29:31
