Date/Time: Sat, 01 Mar 2025 17:29:47 +0000
Denali and Market Depth
View Count: 416
[2021-10-14 21:36:51] |
Steve Leon - Posts: 311 |
I currently have a market depth of 20 on Denali feed for ES futures. It states that you can see the full depth. On Rithmic I know you can see 100. Can you tell me how to see more market depth beyond 20. I looked in the references and under various Global Settings and could not find how to do this Thank you Steven Leon |
[2021-10-14 23:46:39] |
John - SC Support - Posts: 38292 |
The first thing is to ensure that you are getting your data from the Denali Exchange Data Feed. Refer to the following information for the Allow Support for Sierra Chart Data Feeds setting and the information regarding the [M] to tell you that you are getting Sierra Chart data: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) If you have the [M], then refer to the information at the following link for other items to check on: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
