Date/Time: Tue, 26 Nov 2024 00:47:36 +0000
one bar in daily chart
View Count: 1105
[2014-03-28 09:13:27] |
User74010 - Posts: 9 |
I am connected through SC dta services. When I select daily bar charts I only get a single bar. Where can I change that?
[2014-03-28 09:32:52] |
What is the symbol of the chart?
[2014-03-28 09:39:51] |
DAX-201406-DTB [M] and CL-201405-NYMEX [M] |
[2014-03-28 09:43:59] |
Refer to help topic 6.7 here: https://www.sierrachart.com/index.php?l=doc/helpdetails6.html#h6.7 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-28 09:50:50] |
This does not help. The daily bar which is showns is the current day bar. If I select e.g. 240m bars I get bars of previous days. But if i select 1d bars I get just that current day bar
[2014-03-28 09:58:11] |
Select Chart >> Chart Settings. What is the Symbol set to? For DAX-201406-DTB it should be DYM14. Help topic 6.7 specifies to reselect the symbol for the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-28 10:04:02] |
DAX-201406-DTB is the IB symbol which I'm trading on
[2014-03-28 10:10:12] |
Not in the case of the Historical Daily Chart. Please follow through the instructions in help topic 6.7. And reselect the symbol that you actually see listed in the Find Symbol window for Historical Charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
