Date/Time: Sat, 01 Mar 2025 16:57:36 +0000
After Symbol rollover: Different Prices in TPO Chart compared to the Candlestick Chart
View Count: 576
[2021-10-14 17:14:14] |
Dominik - Posts: 2 |
For the CLX21 the symbol rollover was today. When looking at the Market Profile, I noticed the price history/important prices of the previous days doesn't match the Candlestick Chart. For example the TPO Chart says Y-High is at 80.29 (Crude Oil Future) but the Candlestick Chart says 80.36. Also the Volume Profile (TPO compared to Candlestick) is affected. Is there a way to fix this, so the Charts are matching? Thanks! -See attachment- |
[2021-10-14 17:32:04] |
John - SC Support - Posts: 38292 |
The most likely scenario is that the Continuous Futures Contract settings between the charts are different. Refer to the following: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options You would also want to ensure that other items about the charts are the same, such as Session Times and New Bar at Session Start. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
