Date/Time: Wed, 27 Nov 2024 14:45:19 +0000
10 Seconds timeframe on chart shortcut menu
View Count: 1392
[2014-03-28 08:27:59]
phaedonk - Posts: 352
I need to have this option, custom takes too much time. Can you make this happen? Thanks.
[2014-03-28 20:04:10]
This page here documents all of the methods to change the chart bars timeframe:
https://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html
There are no other methods supported or planned.
Date Time Of Last Edit: 2014-04-03 06:33:25
[2014-03-28 20:33:42]
I didn't know you could put a suffix after the number, I guess this will have to do.
However, I was looking for a mouse solution and I am surprised that the documentation page does not mention the way I always use for detached windows: I have added the most used timeframes in the chart shortcut menu, and have also added Custom as seconds is not provided.
[2023-07-31 14:28:20]
User14953 - Posts: 236
phaedonk: "Custom timeframes in the chart shortcut menu." Good on ya! How?
If Anybody has ideas on adding Custom timeframes using any simple Clickable 'no keyboard' method, let us know?
Anybody...
