Date/Time: Sat, 01 Mar 2025 16:52:48 +0000
Datenfeed Probleme
View Count: 670
[2021-10-13 14:52:29] |
User452962 - Posts: 4 |
Hallo, ich kann die Daten von Danali im Sierrachart nur lesen wenn ich die Einstellung "SC DATA - All Services" aktiviere. Ich habe ein AMP Konto, Durchrouting über GQC um die Verbindung zu AMP-Konto zu erhalten. Hierfür muss ich CQG WebAPI einstellen. Ich erhalte dann aber keine Denali Datenfeed mehr. Hier die Antwort vom Support AMP zu dem Problem: "OK. Ich würde empfehlen, sich direkt an den Sierra-Support zu wenden. Möglicherweise verwenden Sie die falsche Plattformversion. (übersetzt)" Gruß Frank |
[2021-10-13 16:11:21] |
John - SC Support - Posts: 38292 |
From Google Translate: Hi there,
I can only read the data from Danali in the Sierrachart if I activate the setting "SC DATA - All Services". I have an AMP account, routing through GQC to get the connection to the AMP account. For this I have to set CQG WebAPI. But then I no longer receive a Denali data feed. Here is the answer from Support AMP to the problem: "OK. I would recommend contacting Sierra Support directly. You may be using the wrong platform version. (Translated)" Greetings Frank You are not fully setup to get data real-time data from the Denali Exchange Data Feed. Depending on the exchanges for which you want to get the data, you will need to follow all the Setup Instructions for the particular exchange. For the CME Group, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For EUREX, follow these instructions: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For CFE, follow these instructions: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_CFE For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
