Date/Time: Sat, 01 Mar 2025 16:53:07 +0000
Weekly bar chart
View Count: 722
[2021-10-13 13:37:21] |
Steve Leon - Posts: 311 |
I am trying to develop a weekly bar chart for ES for cash(pit) session only If use the historical chart it seems to include overnight session If use the intraday setting and i set it to 5 days for cash session only it does not match the chart that i am trying to mimic Can you suggest what i should do ? Is there a way to achieve this on a weekly chart ? That is Bars for the week RTH/cash/pit only ? Thank you Steven Leon |
[2021-10-13 15:12:08] |
John - SC Support - Posts: 38292 |
Refer to the following: Chart Session Times: Day Session Only Weekly Chart Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 22:14:05] |
Very helpful Thank you |
