Date/Time: Sat, 19 Sep 2026 09:06:56 +0000
Chart Trading Mode on: Right-Clk (alternative display)
View Count: 819
| [2021-10-13 12:39:30] |
| User92573 - Posts: 614 |
Dear Support There may be a settings option but I can't see them although I've looked through all the Global trade associated options. When using the chart trading option: Trade >> Chart Trade Mode on. The usual Pointer, Line, Chart values/Crosshair are moved to the right; with the various Chart Trade options on the left. Is there a way to present these in reverse i.e., the Drawing tools etc. left and the Chart Trade features on the right? Many thanks |
| [2021-10-13 15:09:06] |
| John - SC Support - Posts: 47939 |
There is no support for doing this. We have marked this as a Feature Request.
| [2021-10-13 17:53:01] |
Hi, John Thank you for fast the reply. As usual I'm happy to contribute to programming if there's any chance of fast-tracking. The reason behind the request is that I'd like to move to a US Broker and SC/Denali data - so I can use the chart trading option. The problem I have, is that as I'm so used to Sierra Drawing tools (after several years) that I keep executing a sim trade by mistake, as it's just where the drawing tools I am used to are located. If possible please advise me of contribution. Many thanks Paul Update: John, if I rt-clk a drawing object then the chart-trading options are on the right, just as I wanted. But if I rt-click somewhere in the chart, then the chart-trading options are now on the left. Date Time Of Last Edit: 2021-10-13 19:08:01
