Date/Time: Sat, 01 Mar 2025 17:14:06 +0000
Le flux de données n'est pas activé sur le compte
View Count: 412
[2021-10-13 03:33:03]
leversace - Posts: 3
bonjour je n'arrive pas à activer le flux de donné pour me connecter a CQG pour travailler sur l'EUREX, pourriez vous m'aider ?
Cordialement,
Geoffrey LEVERSA
[2021-10-13 14:01:17]
John - SC Support - Posts: 38292
From Google Translate:
hello I can not activate the data feed to connect to CQG to work on EUREX, could you help me?
To connect to CQG, follow the instructions at the following link:
CQG Trading Platform Service: Setup Instructions
That is all you need to do. If you are not getting data from CQG after the setup is complete, then we need to know if you are getting any errors, and what those errors state.
