Date/Time: Sat, 01 Mar 2025 16:52:25 +0000
Sierra Chart Routing
View Count: 406
[2021-10-12 16:51:58] |
mrseho - Posts: 25 |
Hi, I would like to use the sierra Chart routing. I am with AMP and at the moment I have to use CQG for the routing. Is the routing also working with AMP? Would you also do the clearing? Thx for setting up the routing in advance, Sebastian |
[2021-10-12 18:00:25] |
John - SC Support - Posts: 38292 |
Our CME Direct Order Routing is not setup with AMP at this time. Refer to the list of brokers that it is working with at Step #2 of the Setup Instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
