Date/Time: Thu, 06 Mar 2025 22:26:37 +0000
VbP on TPO chart (All Bars in Chart) LEFT ALIGNED
View Count: 501
[2021-10-12 15:49:38]
User263664 - Posts: 23
I have a VbP for all bars in a TPO chart (set as independent volume profile for TPO chart). However it's right aligned, and no matter what I do I can't get it to left align. The option to set right aligned (ln:45) just goes back to 'yes' every time I set it to 'no'. What am I doing wrong?
[2021-10-12 17:49:48]
John - SC Support - Posts: 38464
You are not doing anything wrong, this is the behavior for a VbP that is independent from the TPOs. There is no way to change it.
[2022-02-16 15:57:17]
User542109 - Posts: 3
FWIW, I too would like the ability to move the full chart volume profile to the left
imagesc_support_2.png / V - Attached On 2022-02-16 15:56:41 UTC - Size: 215.57 KB - 135 views
