Date/Time: Sat, 01 Mar 2025 17:27:48 +0000
Scrolling problem
View Count: 444
[2021-10-12 15:49:19]
Paul S. - Posts: 2
I cannot scroll to the right ( into the future) on one of my candlestick charts. The others work fine. How do I fix this? Thanks
[2021-10-12 17:48:36]
John - SC Support - Posts: 38292
Most likely you have the Lock Fill Space option enabled for that chart. Refer to the following:
Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu)
Also refer to the following setting:
Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu)
