Date/Time: Tue, 26 Nov 2024 00:56:19 +0000
Stock Data
View Count: 989
[2014-03-28 01:50:17] |
User22591 - Posts: 133 |
I did no see an answer to my question. Do you provide stock data? If you do does my subscription level give me access to such?
[2014-03-28 02:17:47] |
This was answered here: Stock Data Historical stock data is provided. You have access to it through the Sierra Chart Historical Data service. If you want to use that service separately from the other service you are working with now, then see this page: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
