Date/Time: Tue, 26 Nov 2024 17:34:18 +0000
Data for the S&P Select Sectors
View Count: 1301
[2014-03-27 21:38:48] |
Moti - Posts: 63 |
I am already subscribed to the SC Real-Time and Historical Futures Data Feed ($35/month). Which data feed do I have to add to my subscription in order to get intraday live data of the S&P Select Sectors?
[2014-03-27 23:54:27] |
Could you give us one of the symbols you are referring to.
[2014-03-28 09:17:43] |
Moti - Posts: 63 |
xli , xlk xlb ,xlf ,xlu the 9 sectors of the Spy ( Or IXI ,IXK , IXB , IXF .... ) Date Time Of Last Edit: 2014-03-29 17:50:06
[2014-03-30 03:30:34] |
These symbols will be available once we start providing stock data. Not at this time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-30 03:30:47
[2014-05-29 12:24:42] |
Zosimus - Posts: 345 |
1. any estimate as to when this is this coming ? 2. Is there a place where I can see what is included in the S&P/Dow Jones/CBOE indices that you currently offer with the SC Data Feed (for an extra $3.25) ? |
[2014-05-29 22:03:02] |
1. US equities data is available now: Notice: Sierra Chart Data Feed Now Includes US Equities 2. You can find the complete symbol lists here: http://www.sierrachart.com/index.php?l=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices If there is a particular symbol that you want that you do not see listed in Sierra Chart with the particular Data/Trading service you are using, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
