Date/Time: Sat, 01 Mar 2025 16:30:39 +0000
Rithmic DTC
View Count: 529
[2021-10-12 11:09:54] |
User357489 - Posts: 72 |
Hello, i am currently conducting a challenge that uses R Trader Pro but i can utilise and link my account to SC, by choosing Rithmic DTC data feed, however Sierra Charts is really slow (on the DOM for example) compared to if i just have R trader open- however i use SC mainly, so i wondered if there was a way to speed it up? Thank you Luke |
[2021-10-12 16:21:23] |
John - SC Support - Posts: 38292 |
The main thing to look at is the Chart Update Interval, particularly for a Trading DOM, you can set this fairly low. Refer to the information here: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) It sounds like this could just be the updating speed of the data from Rithmic. If this is the case, then there is nothing we can do about it. Also, refer to the following section (and the one after it) for more information on how to improve the responsiveness of Sierra Chart: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.47 - Use Sub Instances to Distribute Processing Load For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
