Date/Time: Wed, 12 Mar 2025 04:37:05 +0000
Attached Orders with Custom Size Orders
View Count: 1887
[2013-04-23 22:28:33]
CMG - Posts: 179
Hi There,
1. i want to use both automated spreadsheet trading with attached orders, for that I set the CancelAllWorkingOrdersOnExit=YES. The spreadsheet have custom exit orders, so when the first set of the custom order is exited through BuyExit ALL attached orders are canceled. So how can I have both order types using custom orders without this happening?
2. I am using the scale out feature. I would like to scale out the targets but scale in the stops, is this possible?
[2013-04-24 05:28:49]
1.This is inherently difficult when using the Spreadsheet System for Trading study. If you use the ACSIL trading functions you will have more control, but still the actual implementation details of this will have to be worked out by you. This is not simple. Please refer to the ACSIL Trading documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html
2. No. It will affect both Stops and Targets equally.
