Date/Time: Tue, 04 Mar 2025 03:15:16 +0000
FontFace for DRAWING_TEXT
View Count: 651
[2021-10-12 11:00:30] |
User99735 - Posts: 234 |
Hi, FontFace for a manually created DRAWING_TEXT, and font set to something other than Global font, does not get saved to chartbook. On reloading the the text is displayed in default Global font. And accessing the text data through sc_UseTool fetched using sc.GetUserDrawnDrawingByLineNumber also has FontFace as blank. |
[2021-10-13 10:36:25] |
Sierra_Chart Engineering - Posts: 18634 |
FontFace for a manually created DRAWING_TEXT, and font set to something other than Global font, does not get saved to chartbook. Definitely the font face/name is saved. We checked on this. Although test again with the latest release.And accessing the text data through sc_UseTool fetched using sc.GetUserDrawnDrawingByLineNumber also has FontFace as blank. This will be fixed in the next release.
[2021-11-19 14:59:04] |
Similary, accessing the text data through sc_UseTool fetched using sc.GetUserDrawnDrawingByLineNumber does not have the field 'TextAlignment' set correctly.
[2021-11-22 22:22:22] |
Any update on this?
[2021-11-23 04:33:07] |
This is difficult to support, but we will have it supported in the next release.
