Date/Time: Sat, 01 Mar 2025 16:21:24 +0000
[User Discussion] - Strong delta// GBPUSD & GBPJPY (Orderflow)
View Count: 783
[2021-10-12 09:50:06] |
JR2R - Posts: 20 |
Hi, I have a general question about the data feed of FXCM GBPUSD and GBPJPY. Why is it that the strong delta is more present in GBPJPY, than it is in GBPUSD. I've got GJ set to 1000 trades on the tick chart and GU to 700 trades on the tick. Just experimental. I've been using these two instruments for over 10 months and GJ always seems to have strong delta almost every 30 mins, where as GU can go the whole day on the tick with no strong delta being present. Attached is a descpription of what I mean. Any help understanding this concept in terms of the orderflow for FXCM will be appreciated. Many thanks, JR |
[2021-10-12 15:58:18] |
This is not within the scope of our support. However, you should understand how bid volume and ask volume are determined for cash Forex: Chart Data and Chart Data Files: Bid Volume and Ask Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-12 15:59:06
