Date/Time: Sat, 01 Mar 2025 15:57:50 +0000
How can i add horizontal delta on right side of chart?
View Count: 822
[2021-10-12 03:42:50]
riskybiscuit - Posts: 1
im trying to recreate this image i have attached. Specifically the horizontal delta bars. thanks
imageScreenshot_2.png / V - Attached On 2021-10-12 03:41:38 UTC - Size: 129.17 KB - 275 views
[2021-10-12 16:12:12]
John - SC Support - Posts: 38292
We do not think that specific display is from one of our studies. But, you can get close to the same display by using the Volume by Price study and setting the Volume Bars Draw Method to Hologram and then setting the Display Volume in Bars to Ask Volume - Bid Volume or Bid Volume - Ask Volume. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Settings
Keep in mind, you can change the color of the displayed values using Subgraph 7. Refer to the following:
Volume By Price Study: Volume Numbers Text Color and Size (SG7)
And, if you want to hide the Hologram outline, you can set the color to be the same as the background. Refer to the following:
Volume By Price Study: Volume Bars Outline and Fill Colors (SG8)
