Date/Time: Sat, 01 Mar 2025 16:36:57 +0000
Link Quote Board and Intraday Update List
View Count: 555
[2021-10-12 00:48:34]
User566851 - Posts: 20
Hi:
Is there a way to link a global settings > intraday file Update list to a quote board? I guess the same question would stand for the associated watchlist. Thanks.
[2021-10-12 02:33:04]
Thanks for the response. However, that is not linked and I am aware of this method.
[2021-10-12 15:38:15]
John - SC Support - Posts: 38292
There is not a way to do what you want to do directly.
One workaround for the Quote Board and Watchlist is to save the symbol list to file and that same list can be used with the Watchlist. Refer to the following:
Getting Quotes: Saving/Loading Symbol Lists and Importing Symbols
