Date/Time: Sat, 01 Mar 2025 15:56:50 +0000
problem intraday data
View Count: 626
[2021-10-11 15:12:47] |
User740715 - Posts: 26 |
i use rithmic paper trading with Leelo trading and i don't want to load intraday data
[2021-10-11 15:56:50] |
John - SC Support - Posts: 38292 |
We are not understanding. Do you really "don't want to load intraday data"? To not load data for a chart, refer to the following: Chart Settings: Disable Data File Updating (Disable Historical Data Download) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
