Date/Time: Sun, 13 Sep 2026 04:22:26 +0000
How to know if my account is verified?
View Count: 1319
[2021-10-11 11:11:01]
User111079 - Posts: 2
Hi, I'm setting up the Denali live data feed connection to my Sierra Chart account via AMP and CQG. I've signed the Uniform Subscriber Agreement and completed the CME Non-Professional Certification. Before I can move on I need to know if my Sierra Chart account has been verified or not. Where can I see this? Thanks in advance
[2021-10-11 13:13:46]
You need to connect Sierra Chart your funded trading account:
Also try entering your AMP account number here:
https://www.sierrachart.com/UserControlPanel.php?page=AMPTradingAccountVerification
This is another way to do this.
Date Time Of Last Edit: 2021-10-11 13:14:37
[2021-10-11 14:44:44]
John - SC Support - Posts: 47854
If you are connecting to your funded trading account, then you can view the date for which you are verified until at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
At the top of that section is an entry called "Verify Trading Account", that gives the date for which you are verified until.
If you are using the AMP Trading Account Verification, then once you are verified you do not need to think about it again. In order to see your verification status with this method, you would go to the page at the following link:
