Date/Time: Sat, 01 Mar 2025 16:06:56 +0000
CFE /vix data
View Count: 398
[2021-10-11 06:41:28] |
User558455 - Posts: 70 |
Trying get data for VIX futures. Activated CFE but am not getting real time, only historical. Thank you |
[2021-10-11 14:19:46] |
John - SC Support - Posts: 38292 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
