Date/Time: Sun, 13 Sep 2026 05:43:09 +0000
daily 'pit session' futures chart - Denali
View Count: 1157
| [2021-10-08 18:51:15] |
| User877753 - Posts: 152 |
Hello, To get a daily chart, as an example the e-mini S&P 500 for the cash session only (8:30-15:00 CT) I use an intraday chart with the 1-0-0 (days-minutes-seconds) parameter. However, it's quite heavy in resources for a couple of monthss of data. It's a huge load, which is ironic, as only the OHLC of the last bar (the current day) change during the whole session. Is there any other way, like using a daily set of data ? Currently the daily set of data Denali provides includes the full session (23 hours). Same question for other CME and EUREX data. Thanks for your help and suggestions. JM |
| [2021-10-08 19:18:03] |
| cmet - Posts: 742 |
Try intraday with 390 minutes for ES with Evening Session unchecked. Not sure if that'll solve your problem but I've been using it for years with no load issues. |
| [2021-10-08 19:30:24] |
Hi cmet, Thanks for your suggestion. Loading the chart takes the same time with 0-390-0 or 1-0-0 (evening session uncheked for both) : about 20 seconds currently. That'a a bit long, but not so long ; the real issue is that I follow many contracts on many charts, and all that adds up. I think I need to buy a new computer too... |
| [2021-10-09 15:38:34] |
| NotIll - Posts: 122 |
Same 'issue' here.
| [2021-10-10 05:59:20] |
What you need to do is to use a separate instance of Sierra Chart set to use an Intraday Data Storage Time Unit of 1 Minute. Refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
