Date/Time: Sat, 01 Mar 2025 14:04:05 +0000
Trial
View Count: 509
[2021-10-08 15:07:51] |
User841161 - Posts: 245 |
I am currently trying Sierra Charts in the trial version. Is the futures data provided in the trial version live? It seems like it may be delayed. Thanks |
[2021-10-08 16:55:11] |
John - SC Support - Posts: 38292 |
Refer to the following for what real-time data is included with Sierra Chart: Real-Time Data And you also have access to the Delayed Streaming Data (which it sounds like you are already using). Refer to the following: Delayed Exchange Data Feed We really recommend using the Delayed Streaming Data while you are learning how to use Sierra Chart. It acts in all ways, the same as live data, but is delayed by 10-15 minutes. So it works for Simulation Mode within Sierra Chart, and we also offer our Simulated Futures Trading Service for Delayed data. Refer to the following: Simulated Futures Trading Service And finally, refer to the following if you simply have to have live data: Is Historical and Real-time Futures Data Included? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
