Date/Time: Sat, 01 Mar 2025 14:22:46 +0000
Which subscription for $DOWI in real time ?
View Count: 488
[2021-10-08 13:47:17] |
Laurent Donstetter - Posts: 6 |
Hi, Which subscription do I need to have the $DOWI symbol in real time with Denali ? Or maybe did I misconfigure Sierra Chart but I only have historical data. Thank you. Laurent. |
[2021-10-08 14:53:52] |
Easiest and cheapest thing to do is just to use the CFD symbol: US30. Instructions: File Menu: Find Symbol (File) For the actual cash index data from Dow Jones, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
