Date/Time: Sat, 01 Mar 2025 14:06:53 +0000
bitmex and transACT
View Count: 453
[2021-10-08 09:37:04] |
User313942 - Posts: 17 |
Hi. can i trade bitmex and transact togather only switch chart book ? how i do it . wha is options?
[2021-10-08 16:28:48] |
John - SC Support - Posts: 38292 |
The best way to do this is to install a second Sierra Chart and trade BitMex from one and TransAct from the other. Refer to the following information for how to install a second Sierra Chart (there are no additional fees for doing this): Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
