Date/Time: Sat, 01 Mar 2025 13:53:48 +0000
[Programming Help] - Erasing Labels from day or overnight session on switch
View Count: 572
[2021-10-07 22:12:21]
Steve Leon - Posts: 311
I have been setting up the open high and low for the day and overnight sessions on my Trade DOM on ES using study subgraphs. I am writing because I am trying to remove the label from the days open, high and low during the overnight session. I also dont want to display the Globex open after the day session starts. Do you have any suggestions on how to do this. I have been trying by manipulating the settings but have been unsuccessful
I am using a Daily chart with only the Day session (Daily OHLC study) and a 1 minute chart with a Daily OHLC using the Globex(overnight session times.
Thank you very much
Steven Leon
[2021-10-08 00:04:13]
John - SC Support - Posts: 38292
How exactly are you displaying the information in the Trading DOM? What study or tools are you using to do this?
Without knowing the above, if you are just displaying the data using a subgraph (which is what we think you are stating, that is you are not using a Subgraph Value Label), then it sounds like you would need to use a Spreadsheet Study and check the time in order to determine whether to display the information or not.
[2021-10-08 14:24:16]
Thank you very much.
Yes I i am using Study Subgraph on the Trade DOM and basing it off of Studies such as Daily OHLC on a Daily or 1 minute chart. For the overnight levels I was using a 1 min Daily OHLC chart using only the Globex(overnight session)
My goal is to try to put many of the reference levels from my charts onto the Trade DOM. I have done something similar on my TPO charts using either Studies or Study overlay or just manually placing levels with a horizontal line.
I once tried to play around with spreadsheets following the manual instructions but was not able to get very far. I don't know if you can point me to a tutorial showing i can do this. I think i was able to get values onto the spreadsheet bu they were very hard to identify and find. I then was not able to take those values and place them onto the chart as a name or label. I also don't know how you would use time to turn a label off.
Thank you for you r help. I am making good progress with this. Appreciate your help
Steven
[2021-10-08 16:36:54]
The main thing to remember with the Spreadsheet Study is that all the other Studies data are displayed in the Spreadsheet, starting at the end of the Calculation Columns. Refer to the information here:
Using the Spreadsheet Study: Order of Study Data Outputted to Spreadsheet
And also refer to the following:
Using the Spreadsheet Study: Preventing Effect of Changes to Study Order and Subgraphs Outputted on Formula References to Study Subgraphs
So you would want to get your displays as you want them in the Spreadsheet and then use the Study/Price Overlay to display that data in the Trading DOM.
