Date/Time: Sat, 01 Mar 2025 14:20:23 +0000
No position limit set for order
View Count: 611
[2021-10-07 19:49:47]
User308912 - Posts: 1
Hi, maybe you know why i get an error during trade execution - Trade Order Error - No position limit set for order.
I tried setting Use Global Trade Position Limit in Global Symbol Settings also Trade Limit in the ES$ symbol but no luck,
Any help?
thanks
[2021-10-07 23:49:12]
John - SC Support - Posts: 38292
Is this an order to the Simulated Futures Trading Service (Trading Evaluator)? If so, then you need to setup the position limits on the Symbol/Product Limits tab for the symbol(s) you are wanting to trade for the Trading Evaluator. Refer to the following for accessing the Evaluator Editor:
Simulated Futures Trading Service: Setup Instructions
