Date/Time: Sat, 01 Mar 2025 14:31:39 +0000
Message Log popping up automatically..?
View Count: 502
[2021-10-07 18:30:09] |
User68474 - Posts: 202 |
Shall I send you the log from "Send for analysis"? Seems to be about "Windows Error code 10060/SC DTC Data with Market Depth/Disconnected from Server/Will reconnect in 2 seconds/DTC Client socket closed/Connecting to IP," etc., etc. repeat, repeat, etc.
[2021-10-07 23:36:18] |
John - SC Support - Posts: 38292 |
No need to send the log. This is related to the issue described at the following link (which has been resolved at this time): Resolved: Connectivity/Routing Issue for Some Users to Certain Sierra Chart Servers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
