Date/Time: Sat, 01 Mar 2025 14:10:02 +0000
Unable to connect to data feed.
View Count: 475
[2021-10-07 17:36:47] |
User707703 - Posts: 5 |
I tried to log in to Sierra Charts and my data seems to be have trouble downloading.... The connection seems to be ok...but none of my charts are updating with fresh data... I will send along the message log.. Can you help please? Thanks |
[2021-10-07 17:49:03] |
I tried to log in to Sierra Charts and my data seems to be have trouble downloading.... The connection seems to be ok...but none of my charts are updating with fresh data... Keep getting a Windows Error Code 10060 which is a connect error as well Can you help please? Thanks |
[2021-10-07 17:53:12] |
John - SC Support - Posts: 38292 |
Refer to the following: Resolved: Connectivity/Routing Issue for Some Users to Certain Sierra Chart Servers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
