Date/Time: Tue, 26 Nov 2024 00:29:39 +0000
Send for analysis
View Count: 1259
[2014-03-27 14:05:26] |
User27605 - Posts: 9 |
This is to inform you I sent for analysis. Thank you.
[2014-03-27 17:57:01] |
Checking on this now.
[2014-03-27 18:05:41] |
Our impression of this, is that possibly the bridge program is not actually starting up. Might be caused by security software you are running on your system. And refer to the information here: https://www.sierrachart.com/index.php?l=doc/TransAct.php#BridgeConnectionError If you still need help with this, you may need to contact TransAct support: http://www.transactfutures.com/ContactUs.htm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
