Date/Time: Sat, 01 Mar 2025 13:52:21 +0000
Connecting/disconnecting problem
View Count: 539
[2021-10-07 17:12:33]
sax - Posts: 5
My SC keeps throwing errors in the message log over and over. just started doing this about an hour ago.
Triggering next historical data download in queue. | 2021-10-07 17:07:14.376
HD Request # 96 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-10-07 17:07:14.376
HD Request # 96 | Download start date-time: 2021-10-07 16:55:23.000000. File last date-time: 2021-10-07 16:55:23.000000 | 2021-10-07 17:07:14.376
HD Request # 96 | Using server: ds4.sierracharts.com port 10149 | 2021-10-07 17:07:14.376
Socket (3) | Creating socket. | 2021-10-07 17:07:14.376
Socket (3) | New receive buffer size: 5242880 | 2021-10-07 17:07:14.376
Socket (3) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:07:14.376
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 17:07:21.447 *
DTC Client socket (1) | CloseSocket call. | 2021-10-07 17:07:21.447
DTC Client socket (1) | Closed. | 2021-10-07 17:07:21.447
DTC Client socket (0) | CloseSocket call. | 2021-10-07 17:07:21.447
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 17:07:21.447
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 17:07:21.447
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2021-10-07 17:07:23.439
DTC Client socket (1) | Creating socket. | 2021-10-07 17:07:23.439
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-07 17:07:23.439
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:07:23.439
Socket (3) | CloseSocket call. | 2021-10-07 17:07:34.373
Socket (3) | Closed. | 2021-10-07 17:07:34.373
HD Request # 96 | Error downloading historical Intraday data for USOil. Timeout error connecting to server. | 2021-10-07 17:07:34.373
Added historical Intraday data request for USOil to the queue. | 2021-10-07 17:07:34.373
Triggering next historical data download in queue. | 2021-10-07 17:07:34.373
Historical data download thread signaled to stop. | 2021-10-07 17:07:34.373
HD Request # 96 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for USOil | 2021-10-07 17:07:34.373
HD Request # 96 | Completion time: 20s | 2021-10-07 17:07:34.373
HD Request # 97 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-10-07 17:07:34.374
HD Request # 97 | Download start date-time: 2021-10-07 16:55:23.000000. File last date-time: 2021-10-07 16:55:23.000000 | 2021-10-07 17:07:34.374
HD Request # 97 | Using server: ds12.sierracharts.com port 10150 | 2021-10-07 17:07:34.374
Socket (3) | Creating socket. | 2021-10-07 17:07:34.374
Socket (3) | New receive buffer size: 5242880 | 2021-10-07 17:07:34.374
Socket (3) | Connecting to IP: 204.15.197.14. | 2021-10-07 17:07:34.374
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 17:07:44.473 *
DTC Client socket (1) | CloseSocket call. | 2021-10-07 17:07:44.538
DTC Client socket (1) | Closed. | 2021-10-07 17:07:44.538
DTC Client socket (0) | CloseSocket call. | 2021-10-07 17:07:44.538
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 17:07:44.538
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 17:07:44.538
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-10-07 17:07:46.701
DTC Client socket (1) | Creating socket. | 2021-10-07 17:07:46.701
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-07 17:07:46.702
DTC Client socket (1) | Connecting to IP: 204.15.197.14. | 2021-10-07 17:07:46.702
Socket (3) | CloseSocket call. | 2021-10-07 17:07:54.386
Socket (3) | Closed. | 2021-10-07 17:07:54.387
HD Request # 97 | Error downloading historical Intraday data for USOil. Timeout error connecting to server. | 2021-10-07 17:07:54.387
Added historical Intraday data request for USOil to the queue. | 2021-10-07 17:07:54.387
Triggering next historical data download in queue. | 2021-10-07 17:07:54.387
Historical data download thread signaled to stop. | 2021-10-07 17:07:54.387
HD Request # 97 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for USOil | 2021-10-07 17:07:54.387
HD Request # 97 | Completion time: 20s | 2021-10-07 17:07:54.387
HD Request # 98 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-10-07 17:07:54.387
HD Request # 98 | Download start date-time: 2021-10-07 16:55:23.000000. File last date-time: 2021-10-07 16:55:23.000000 | 2021-10-07 17:07:54.387
HD Request # 98 | Using server: ds4.sierracharts.com port 10149 | 2021-10-07 17:07:54.387
Socket (3) | Creating socket. | 2021-10-07 17:07:54.387
Socket (3) | New receive buffer size: 5242880 | 2021-10-07 17:07:54.387
Socket (3) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:07:54.387
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 17:08:07.720 *
DTC Client socket (1) | CloseSocket call. | 2021-10-07 17:08:07.720
DTC Client socket (1) | Closed. | 2021-10-07 17:08:07.720
DTC Client socket (0) | CloseSocket call. | 2021-10-07 17:08:07.720
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 17:08:07.720
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 17:08:07.720
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2021-10-07 17:08:09.722
DTC Client socket (1) | Creating socket. | 2021-10-07 17:08:09.722
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-07 17:08:09.722
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:08:09.722
[2021-10-07 17:24:46]
Technical - Posts: 158
Same with me, just started today.
DTC Client socket (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 12:22:15.578 *
DTC Client socket (4) | CloseSocket call. | 2021-10-07 12:22:15.582
DTC Client socket (0) | CloseSocket call. | 2021-10-07 12:22:15.582
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 12:22:15.582
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 12:22:15.582
DTC Client socket (4) | Closed. | 2021-10-07 12:22:15.582
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2021-10-07 12:22:17.583
DTC Client socket (4) | Creating socket. | 2021-10-07 12:22:17.583
DTC Client socket (4) | New receive buffer size: 5242880 | 2021-10-07 12:22:17.583
DTC Client socket (4) | Connecting to IP: 204.15.197.14. | 2021-10-07 12:22:17.583
SC DTC Data with Market Depth | Network connection to server complete. | 2021-10-07 12:22:17.636
SC DTC Data with Market Depth | Starting socket receive thread. | 2021-10-07 12:22:17.636
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-10-07 12:22:17.636
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-10-07 12:22:18.639
SC DTC Data with Market Depth | Sending logon request message. | 2021-10-07 12:22:18.639
[2021-10-07 17:32:12]
58LesPaul - Posts: 429
Mine also. I disconnected and reconnected and it stopped. Is you all's still doing it?
[2021-10-07 17:44:53]
John - SC Support - Posts: 38292
We are looking into this now.
[2021-10-07 18:09:45]
Gary Number 2 - Posts: 130
I am having severe (connect/disconnect continuously) disconnect issues with Denali Data, CQG routing, & amp broker. FYI
All other trading platforms have been fully connected while this occurs.
[2021-10-07 18:20:52]
I shut down completely, launched Sierra Chart - no change, still disconnecting.
[2021-10-07 19:00:56]
Regarding post #5, you should not be having any problems with the Denali Data Feed. We are not observing any problems with the Denali data feed.
Refer to:
Resolved: Connectivity/Routing Issue for Some Users to Certain Sierra Chart Servers
And regarding CQG connectivity we cannot help with that.
Regarding post #6, you definitely should not be having any problems with the Denali data feed or the SC order routing. Those services are unaffected. We do not know what is disconnecting.
Date Time Of Last Edit: 2021-10-07 19:02:32
