Date/Time: Sat, 01 Mar 2025 13:51:39 +0000
Message log keeps popping up with connecting/disconnecting
View Count: 508
[2021-10-07 17:12:07]
sax - Posts: 5
Message log keeps popping up with connecting/disconnecting and wont stop
Triggering next historical data download in queue. | 2021-10-07 17:07:14.376
HD Request # 96 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-10-07 17:07:14.376
HD Request # 96 | Download start date-time: 2021-10-07 16:55:23.000000. File last date-time: 2021-10-07 16:55:23.000000 | 2021-10-07 17:07:14.376
HD Request # 96 | Using server: ds4.sierracharts.com port 10149 | 2021-10-07 17:07:14.376
Socket (3) | Creating socket. | 2021-10-07 17:07:14.376
Socket (3) | New receive buffer size: 5242880 | 2021-10-07 17:07:14.376
Socket (3) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:07:14.376
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 17:07:21.447 *
DTC Client socket (1) | CloseSocket call. | 2021-10-07 17:07:21.447
DTC Client socket (1) | Closed. | 2021-10-07 17:07:21.447
DTC Client socket (0) | CloseSocket call. | 2021-10-07 17:07:21.447
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 17:07:21.447
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 17:07:21.447
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2021-10-07 17:07:23.439
DTC Client socket (1) | Creating socket. | 2021-10-07 17:07:23.439
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-07 17:07:23.439
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:07:23.439
Socket (3) | CloseSocket call. | 2021-10-07 17:07:34.373
Socket (3) | Closed. | 2021-10-07 17:07:34.373
HD Request # 96 | Error downloading historical Intraday data for USOil. Timeout error connecting to server. | 2021-10-07 17:07:34.373
Added historical Intraday data request for USOil to the queue. | 2021-10-07 17:07:34.373
Triggering next historical data download in queue. | 2021-10-07 17:07:34.373
Historical data download thread signaled to stop. | 2021-10-07 17:07:34.373
HD Request # 96 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for USOil | 2021-10-07 17:07:34.373
HD Request # 96 | Completion time: 20s | 2021-10-07 17:07:34.373
HD Request # 97 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-10-07 17:07:34.374
HD Request # 97 | Download start date-time: 2021-10-07 16:55:23.000000. File last date-time: 2021-10-07 16:55:23.000000 | 2021-10-07 17:07:34.374
HD Request # 97 | Using server: ds12.sierracharts.com port 10150 | 2021-10-07 17:07:34.374
Socket (3) | Creating socket. | 2021-10-07 17:07:34.374
Socket (3) | New receive buffer size: 5242880 | 2021-10-07 17:07:34.374
Socket (3) | Connecting to IP: 204.15.197.14. | 2021-10-07 17:07:34.374
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 17:07:44.473 *
DTC Client socket (1) | CloseSocket call. | 2021-10-07 17:07:44.538
DTC Client socket (1) | Closed. | 2021-10-07 17:07:44.538
DTC Client socket (0) | CloseSocket call. | 2021-10-07 17:07:44.538
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 17:07:44.538
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 17:07:44.538
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-10-07 17:07:46.701
DTC Client socket (1) | Creating socket. | 2021-10-07 17:07:46.701
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-07 17:07:46.702
DTC Client socket (1) | Connecting to IP: 204.15.197.14. | 2021-10-07 17:07:46.702
Socket (3) | CloseSocket call. | 2021-10-07 17:07:54.386
Socket (3) | Closed. | 2021-10-07 17:07:54.387
HD Request # 97 | Error downloading historical Intraday data for USOil. Timeout error connecting to server. | 2021-10-07 17:07:54.387
Added historical Intraday data request for USOil to the queue. | 2021-10-07 17:07:54.387
Triggering next historical data download in queue. | 2021-10-07 17:07:54.387
Historical data download thread signaled to stop. | 2021-10-07 17:07:54.387
HD Request # 97 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for USOil | 2021-10-07 17:07:54.387
HD Request # 97 | Completion time: 20s | 2021-10-07 17:07:54.387
HD Request # 98 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-10-07 17:07:54.387
HD Request # 98 | Download start date-time: 2021-10-07 16:55:23.000000. File last date-time: 2021-10-07 16:55:23.000000 | 2021-10-07 17:07:54.387
HD Request # 98 | Using server: ds4.sierracharts.com port 10149 | 2021-10-07 17:07:54.387
Socket (3) | Creating socket. | 2021-10-07 17:07:54.387
Socket (3) | New receive buffer size: 5242880 | 2021-10-07 17:07:54.387
Socket (3) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:07:54.387
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-10-07 17:08:07.720 *
DTC Client socket (1) | CloseSocket call. | 2021-10-07 17:08:07.720
DTC Client socket (1) | Closed. | 2021-10-07 17:08:07.720
DTC Client socket (0) | CloseSocket call. | 2021-10-07 17:08:07.720
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-07 17:08:07.720
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-10-07 17:08:07.720
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2021-10-07 17:08:09.722
DTC Client socket (1) | Creating socket. | 2021-10-07 17:08:09.722
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-07 17:08:09.722
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-10-07 17:08:09.722
[2021-10-07 17:30:28]
John - SC Support - Posts: 38292
The following messages are the reason for this:
You are having a network issue. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
