Date/Time: Sat, 01 Mar 2025 14:09:46 +0000
I can not play
View Count: 495
[2021-10-07 12:52:01] |
User657856 - Posts: 61 |
I cannot place a Buy Stop transaction or Sell Stop using the Chart Values Tool. When I give a Cross and Buy Stop, the Buy Stop and Stop Loss lines appear and they immediately disappear. So I cannot make a purchase transaction. The same is true for a Sell Stop transaction. How to fix it? Kind regards Bogdan Date Time Of Last Edit: 2021-10-07 13:35:33
[2021-10-07 14:56:48] |
Set this setting to yes: Global Settings >> Tool Settings >> Chart Values >> Always On when Chart Values Tool Selected. Refer to: Chart Drawing Tools: Always On When Chart Values Tool Selected (Tool Settings >> Chart Values >> Chart Values) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-07 14:57:01
