Date/Time: Sat, 01 Mar 2025 14:16:53 +0000
Can't Find S&P/TSX Composite Index Symbol in SC Data Service
View Count: 433
[2021-10-07 04:52:49] |
ChrisH - Posts: 10 |
Hello, I cannot find the symbol for the TSX Composite Index (Toronto Stock Exchange) in the SC Data service. I had accessed a TSX composite index a number of months ago. Has there been a change? I've scanned through the symbol list & searched the support board for any mention. Thanks. |
[2021-10-07 15:14:16] |
John - SC Support - Posts: 38292 |
Look through the TSX indices listed at the following link to see if you can find the particular one you are looking for: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices#INDEX-SP Those indices are part of the Sierra Chart Exchange Data Feed and are available for real-time data by activating the S&P Indices exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
