Date/Time: Fri, 18 Sep 2026 09:42:48 +0000
Setting cumulative Delta on my chart
View Count: 1859
| [2021-10-07 03:38:02] |
| User918591 - Posts: 20 |
Hello, can you tell me how to set up cumulative Delta Bars-Volume on my chart as it is on the attached screen shot called "cumulative Delta" ? I have attached another screen shot that is showing the display of the current cumulative delta I have and I want my cumulative delta to look like the one on the screen shot called "cumulative Delta". Regards, |
| [2021-10-07 14:57:40] |
| John - SC Support - Posts: 47930 |
You are using the correct study, you just have the bars too close together to see them individually. Expand your time scale to see it more like the image you want it to look like. Refer to the following for how to expand your time scale: Working With Charts: Changing Bar Spacing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
