Date/Time: Tue, 26 Nov 2024 00:58:20 +0000
Custom Text on Horizontal Ray possible to put in?
View Count: 1422
[2014-03-27 10:24:11] |
4646ed - Posts: 230 |
is it possible to put a Custom Text label on the Horizontal Ray? If not, could you set that up? |
[2014-03-27 12:01:32] |
tobi - Posts: 351 |
Right click on the Horizontal Ray and choose Modify Text. Make sure, that you have Modify Text in the Selected Menu Items list in Global Settings >> Customize Chart Drawing Menu |
[2014-03-28 13:38:40] |
thanks, tobi.
