Date/Time: Sat, 01 Mar 2025 14:17:43 +0000
all of my charts are blank
View Count: 692
[2021-10-06 21:03:30]
cmb999 - Posts: 211
not sure when it started, since ive been away from mkt a few days
message log sent separately via the application
[2021-10-07 00:25:14]
John - SC Support - Posts: 38292
The first issue is that you need to connect to your live trading account in order to authorize the CME Group Non-Professional status. Your current verification date ended today (October 6, 2021).
But, because of this, you would be receiving the Delayed Exchange Data, and that is what your Message Log shows. We do not see any errors in terms of getting the delayed data, so you should have data displayed in your charts.
Please check the basics, such as making sure that Chart >> Graph Draw Type is not set to blank. Or that your Session Times are somehow not set correctly.
If you still have a problem after this, then we need to see a screenshot of what you are seeing (there is helpful information even if it is blank). You can add a screenshot to this thread by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
[2021-10-07 01:40:28]
cmb999 - Posts: 211
thank you, my pc needed a reboot
