Date/Time: Sat, 01 Mar 2025 12:55:27 +0000
volume problem dom
View Count: 371
[2021-10-06 17:52:19]
karaamohamed - Posts: 7
Here is a screen of my graphs, you can see that there are less volume and depth lines on some graphs compared to others; how can I fix this?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=55661
[2021-10-06 18:24:47]
John - SC Support - Posts: 38292
Make sure you have not limited the number of depth levels. Refer to the following for places to check:
File Menu: Not Receiving the Full Number of Market Depth Levels
