Date/Time: Sat, 01 Mar 2025 12:47:53 +0000
Move from Tradovate to Sierra Chart
View Count: 855
[2021-10-06 17:29:27] |
duandre - Posts: 1 |
I currently have a Dorman Trading account through Tradovate. I want to remove Tradovate from the process and do everything through Sierra Chart with the Sierra Chart order routing and the Denali Exchange Data Feed. I am not clear on the best process to do this. I don't want to pay Tradovate any commission since I won't be using their platform for anything. The one person I managed to get on the phone at Dorman wants me to open a new account for Sierra Chart or use Sierra Chart to go through Tradovate. I see no point in paying Tradovate to be in the middle. I'd like to keep Dorman because I already have a funded account with them. Is there an easy way to do this or is it more trouble than it is worth? I will open a new account with Dorman, or with another if there is a better option, if that is the best way to go. |
[2021-10-06 19:24:50] |
Sierra_Chart Engineering - Posts: 18607 |
You probably need to move to a different introducing broker at Dorman. You could move to Stage 5 or Edge Clear. For now you could go to the broker Stage 5 and the clearing firm Advantage futures and take advantage of our new direct order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
