Date/Time: Sat, 01 Mar 2025 13:22:26 +0000
Does Sierra Chart still work with Gain Trader?
View Count: 630
[2021-10-06 02:41:26] |
fuzzy - Posts: 7 |
It used to work. But I don't find it on the supported Data/Trade Services anymore.
[2021-10-06 14:36:51] |
John - SC Support - Posts: 38292 |
It is in the listed services as Gain Capital/OEC. You should see it. Just note that your account is expired, so you it will have a statement about not being available. Just be aware that although the connectivity is still there, we no longer do any updates or changes to the connection, so we can not say whether it will continue to work, or help if you have any issues with the connection. To connect, you will need to have an active account. Refer to the following for how to reactivate your account: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-06 14:59:08] |
It is supported. It is called Gain Capital. Follow the instructions here to set the Current Selected Service: Data/Trade Service Settings: Main Settings (Global Settings >> Data/Trade Service Settings) (Global Settings >> Data/Trade Service Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-06 15:05:15
