Date/Time: Sat, 01 Mar 2025 12:59:56 +0000
Historical & Intraday data source
View Count: 726
[2021-10-05 18:07:36]
WFitton - Posts: 4
As I have recently changed my data feed from CQG to Denali, could you advise me what the recommended historical and intraday data source to use with symbol settings ES?## are please ?
[2021-10-05 18:26:23]
John - SC Support - Posts: 38292
You should not be changing those, you want to leave them as they are.
When you change Services, the symbol information updates for the service you are using.
In general, you should have very little reason to change Symbol Settings. Is there something in particular you are wanting to accomplish for which we can help you?
[2021-10-05 19:23:52]
WFitton - Posts: 4
Hi John,
Thank you for your reply.
There is nothing in particular I want to accomplish only to know that the setting I have are correct now that I am receiving the dat from Seirra Denali.
The setting I have in Symbol Settings are:
Historical Daily Data Source = external historical data service.
and
Historical Intraday Data Service = exchange data service.
If you can confirm these settings are correct or not it will be much appreciated.
All the best and thank you for your time .
Wesley
[2021-10-05 23:52:22]
Yes, those are the correct settings for those entries.
[2021-10-06 18:02:11]
Sierra_Chart Engineering - Posts: 18607
You will always want to leave those settings at their default and not override them.
Date Time Of Last Edit: 2021-10-06 18:02:21
