Date/Time: Sat, 01 Mar 2025 13:31:12 +0000
bitmex
View Count: 552
[2021-10-05 16:31:02] |
User313942 - Posts: 17 |
HI . i connected to bitmex , but symbol list is empty. how i add symbols?
[2021-10-05 18:43:11] |
Sierra_Chart Engineering - Posts: 18607 |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 19:03:18] |
User651547 - Posts: 68 |
HI . this is no help . the symbol list is empty.
[2021-10-05 19:08:12] |
File attached
[2021-10-06 15:17:14] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log After updating the Symbol Settings provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) This will provide us the additional information we need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-06 15:17:28
