Date/Time: Sat, 01 Mar 2025 13:01:59 +0000
Replay charts with low day count
View Count: 575
[2021-10-05 13:52:47] |
quin6 - Posts: 22 |
Hi, My computer isn't the best and has trouble loading lots of days with the indicators that i use. I wish to do replays with the indicators but cant load less than 25 days on the replay. When i try to load for example, 5 days... It doesn't load any data. In other words the replay function isnt allowing me to load less than 25 days, period. With or without indicators. Date Time Of Last Edit: 2021-10-05 13:56:45
[2021-10-05 17:39:08] |
John - SC Support - Posts: 38292 |
How are you starting the replay, are you scrolling the chart back to where you want to start or are you selecting the option on for Use Start Date-Time on the Replay Window? In either case, just make sure that you are only selecting (going to) a day that is 5 days ago. There is no reason why you should not be able to replay only 5 days. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 17:47:39] |
quin6 - Posts: 22 |
I'm using Use [Start Date-Time] on the Replay Window! Oh Ok am I limited to only going to a day that's 5 days ago from today? Or can I say, load a 5 day period from 6 months ago? I wish to do the prior. Date Time Of Last Edit: 2021-10-05 17:48:17
[2021-10-05 18:17:43] |
On the replay, you are not limited to how far back you want to go, be it one minute, one day, or five days. You can also specify a date 6 months prior and stop the replay after five days have passed, but you have to manually do this. But, you can not (within the replay realm) specify a 5 day period 6 months prior that you want to replay and have it automatically stop at the end of those 5 days. To do this, you need to first setup your chart to just have that data in it by using the Chart >> Chart Settings >> Use Date Range - From/To. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Once the chart has just the 5 days you want to replay, then you can set the beginning of the replay and it will just replay the data that is available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 18:35:38] |
quin6 - Posts: 22 |
You're awesome thank you so much.
